09-05-2016
01:47 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-05-2016
01:47 PM
>> i need section properties of the region
Not sure if my guessing is correct now. ;(
"the region" is irritating here as "region" is a name of an AutoCAD object type and you have send a drawing with 2 blue regions, if you want to have the mass-properties of the outer region MINUS the inner region you have first to run command _SUBTRACT (to make the inner region an island for the outer one) and then you can run _MASSPROP to get that value.
When you start _MASSPROP and select multiple regions you always get the summed value, AutoCAD does not subtract anything as long as that are separate objects.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
