smane
en respuesta a: smane
Hello
I had a CAD file attached to my question, but please see attached here
Also attached is the PDF with my notes/comments
I am available to talk if needed
Sandeep
480-213-8524
From: Autodesk Community [mailto:community@noreply.autodesk.com]
Sent: Monday, September 05, 2016 12:39 PM
To: smane@abneng.com
Subject: Re: Massprop (Autodesk Community Subscription Update)
Autodesk_logo
Activity on a Thread You're Following - Description:
http://forums.autodesk.com/html/assets/autodesk_blue_banner.png
Hi smane,
Alfred.NESWADBA (Mentor) posted a new reply in AutoCAD
2013/2014/2015/2016/2017
on 09-05-2016 12:38 PM :
_____
Re: Massprop
/6543093#M139917>
welcome @Anonymous
.autodesk.com!
Can you please describe your situation again? It's (at least for me) not
clear who selects what and which objects you are checking/selecting, which
values you get and why you think that they are wrong.
Just to show you what is not clear:
>> when I enter "Massprop" command then it selects a inside region
>> of interior circle + inside region of outside circle
Command _MASSPROP does not select anything, when I start the command I'm
asked to select an object.
>> selects a inside region of interior circle + inside region of outside
circle.
There is not any circle in the drawing.
If you mean "inside polygon" and "outside polygon" ... there are two of each
types, one on layer "P-TOWER" and another one on layer "DEFPOINT", which
ones are you referring to?
>> SO the values that I am getting are not correct
Which values do you get?
And why do you think that they are not correct?
- alfred -
lithium.com?subject=Re:%20Massprop> | Accept as Solution
tion=autodesk.prod%7C4ee80ec0%7C3a84f5c0-d72c-43f6-8f70-04f4df7e0d19&dest_ur
l=http%3A%2F%2Fforums.autodesk.com%2Ft5%2Fautocad-2013-2014-2015-2016-2017%2
Fmassprop%2Fm-p%2F6543093%23M139917&ticket=sVGxOwNk4jCV_4032402> | Give
Kudos
tion=autodesk.prod%7C620b0f4a%7C264faa53-cdec-496a-bf08-dc55049dab59&dest_ur
_____
Thanks for being a Autodesk Community member.
Your Autodesk Community Team
You're receiving this because you registered for the Autodesk Community.
Manage your notification settings
or unsubscribe
-message-tracking/ISQG9Y2TGIHYT8>
Select a different language
for
these emails.
To get the most out of your product, visit the Autodesk Knowledge Network
Privacy | Legal Notices
& Trademarks | CCopyright 2016 Autodesk Inc. All rights reserved
