JamieVJohnson2
en respuesta a: JamieVJohnson2
I did some testing this morning this is definitely a program bug with the use of the NTSF Junction.  I removed the junction, ran the X-ref test directly to drive D and everything worked.  Then I put it back, opened that same file, then simply went to Xref manager, and change the path from D:\ to C:\ where it would have to use the junction, and it stalled out.
Can anybody else confirm?
Autodesk please hot fix AutoCAD 2017 quickly, this is a fundamental flaw in the program.  I'd really like to use the 2017 version if I could.
jvj
