883 Vistas, 6 Respuestas
08-29-2016
05:16 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-29-2016
05:16 AM
Hi!
When I am using the tool Dimension - Angular the angular text is not appearing at all. Normally the text appears over the arc created by the tool you know.
I suspect there is some setting I need to check but I cant even find the settings, I'm new to Autocad 2014..
Using Autocad 3D Map 2014 och PC Windows 7.
Thanks in advance!
/Joakim
¡Resuelto! Ir a solución.
