876 Vistas, 6 Respuestas
Dimension angular text not appearing
Hi!
When I am using the tool Dimension - Angular the angular text is not appearing at all. Normally the text appears over the arc created by the tool you know.
I suspect there is some setting I need to check but I cant even find the settings, I'm new to Autocad 2014..
Using Autocad 3D Map 2014 och PC Windows 7.
Thanks in advance!
/Joakim
imadHabash
en respuesta a: Anonymous
Hi and welcome to AutoDesk Forum,
I suggest to check Text height ....
Imad Habash
en respuesta a: imadHabash
Thanks but where do I find that setting? I have been looking around for the settings for Dimension Angular text but I cant find it.
dbroad
One of at least 3 places: a)Dimstyle, b)Style, and as an object override (in properties).  Whether the text is annotative or not also is a factor.
Architect, Registered NC, VA, SC, & GA.
imadHabash
for AutoCAD use DDIM command line.prepare all of your settings then set it current.
Good Luck..
Imad Habash
rkmcswain
Erase everything except the dimension, save the drawing, and post it here.
Otherwise, we are all just guessing.
en respuesta a: rkmcswain
Seems like the "dim scale overall" was set to 0.0001 for some reason, changed it to 1 and problem solved. Thanks alot for your fast replies and support!
