HullDrafter
2069 Vistas, 4 Respuestas
In Autocad 2016, can the "Pan" Icon be changed back to a solid white color?
Currently, it is a white outline around a black hand. My boss was curious if it could be changed back. I haven't found an answer yet, perhaps someone can tell me, if this is possible or not.
Thank you,
HD
john.vellek
en respuesta a: HullDrafter
HI @HullDrafter,
I am not even sure where the icon is to tell the truth!  However, if you type CUI and scroll through the command list you should be able to find PAN. If you select it you will see the button image displayed on the top right of the window. There is also an Edit button that would allow you to manually edi the image.
John Vellek
HullDrafter
en respuesta a: john.vellek
Thank you for the suggestion. A co-worker and I tried various combinations but it didn't work.
Thank you,
HD
john.vellek
HI @HullDrafter,
If you liked the one available in AutoCAD 2013, I have attached it here for you. Again, open CUI, select the pan command and then click the edit button for the Button image. You will then see an Import button in the editor which will allow you to import the attached file.
John Vellek
john.vellek
Hi @HullDrafter,
Did you try importing the image I gave you? I am hoping that it helped with your issue.
John Vellek
