Alfred.NESWADBA
en respuesta a: Anonymous
>> Things like viewres and facetres I already changed
Have you also tried command _REGEN after zooming close to details?
Is your hardware acceleration turned on of off (try both) (command _GRAPHICSCONFIG)
Can you upload the drawing?
How were these solids created? using command _CIRCLE and _EXTRUDE or _PRESSPULL or did you use _CYLINDER or have you got the geometry from anywhere else?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
