1210 Vistas, 4 Respuestas
When click point and transfer it to Excel.
I have been work that i get point of coordinate XYZ value and then transfer it to Excel by using Click2XLS(lisp command).
I click points about 1,000 everyday.
However, i think that the way take a long time to finish work also i often mistake such as missing points, forgetting point number.
Therefrore, is there more fast way that point of coordinate XYZ value to Excel?.
Patchy
en respuesta a: Anonymous
After have all points in the drawing, export them using this:
http://www.lee-mac.com/ptmanager.html
john.vellek
Hi @Anonymous, Are the points contained in blocks? If so, you can easily add an attribute field to capture the location and then use a data extraction to get the information into Excel.
Let me know if this sounds like it can work for you. I would be happy to provide additional information and resources to you.
John Vellek
Pointdump
S,
I like John's method with data extraction.
Dave S
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
en respuesta a: Patchy
Im very interested in your answer.
When i use the lisp command(pt manager) that you recommanded, i can get very easliy point of XYZ value at Excel.
However, my worked point is numbered sequentially along line.
The point of coordinate XYZ value randomly sorted at Excel.
All i need is that the numbered point will sorted sequentially at Excel.
Thanks you answer.
