Alfred.NESWADBA
en respuesta a: Anonymous
>> The software is called "Cube Print"
I guess most software packages do have the option to scale the STL content, so also scaling your object X=70%, Y=70% and Z=100% (as you had scaled the blockreference) should work well.
For your drawing: I don't know what happened to your block as I don't see the block-content in modelspace. But at least to explode a block with different X/Y/Z-scalings is always an issue (also from geometry side). If you do have the original path and contour I would first change the path in Z-direction (height of helix) and then create the 3D-solid from scratch.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
