705 Vistas, 5 Respuestas
unable to save DWG TO DXF
Hello everyone,
After trying Audit, Purge, DXFOUT, still fail to save DWG to DXF.
I have attached the sample here.
Looking forward to seeing your replies.
imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoDesk Forum,
i suggest to use -EXPORTTOAUTOCAD command line first,then open the new CAD file then use DXFOUT. it works fine with me.
Good Luck...
Imad Habash
john.vellek
Hi @Anonymous,
I too ran an Exporttoautocad to get the dxf export to work.  I also noticed that a -purge>Regapps had 65 apps removed.
I hope this helps.
John Vellek
john.vellek
HI @Anonymous,
Did imadhabash's solution or mine help you to get your DXF created?
Please update your post with your results.
John Vellek
en respuesta a: imadHabash
Thank you Imadhabash.
After convert to AutoCAD 2010 or lower version CAD files, it can be saved as DXF.
en respuesta a: john.vellek
Hi John, Exporttoautocad works. Thanks you so much!
