- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
your drawing is successfully uploaded now ![]()
It contains 3D-Solid objects which can directly be exported as STL.
And the two blockreferences (with the name "A$C3AD50F07") are not that easy to identify, copying the content of the blockdefinition into a new drawing shows what it should be, but I don't see the content in modelspace ... strange.
What did you do to get such a blockname? Or did you create this part with another software and imported it into AutoCAD?
However, which program do you use to convert the STL to GCODE for your printer?
Most appications (e.g. Cura or Simplify3D) do have the option to do their own scaling and that is what I would do, create the 3D-Solid with scale 1 and then rescale the Z-value in your slicing application ... will that work?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
