- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am laying out a roof plan. I would like the representation of the beam on my plan to have information attached to it such as beam type, size and span. This would make it possible to automatically populate a beam schedule. Is this possible?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This can be done in a few ways but there may be a ready made solution with products like advanced steel or MEP. Have you looked into using one of the autocad verticals?
http://www.autodesk.com/products/advance-steel/features/all/list-view
http://www.autodesk.com/products/autocad-mep/overview
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
With vanilla AutoCAD? Not available OOTB (out of the box), however with some customization that is possible. Might also want to look into the Advance Steel package, as well as various third-party structural design programs.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Blocks with Attributes might get you what you need.
This is available in vanilla AutoCAD.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
If you are doing something fairly simple, I can envision doing this with dynamic blocks or blocks with attributes. Otherwise, a vertical product might be more appropriate.
If you want to attach a sample drawing I am happy to take a look for you and make some suggestions.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Brian Hadley
352 East Riverside Drive Suite A2
St. George, Utah 84790
Phone (435) 673-8586
Fax (435) 673-8397
[RALogo_Titleblock_Red_w_gray]
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Brian, Unfortunately, your attachment didn't stick. Can you put it in a ZIP file and try again? You might also try turning off your Firewall temporarily.
I look forward to working on this for you.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous, I am happy to help you with this but the Zip didn't get attached. Can you try once more - perhaps turning off your firewall and using a different browser? If that doesn't work I will shoot you a PM that you can respond and attach to.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Here it is.
File attachment added by John Vellek as OP was unable to attach it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Thanks for the files! Unfortunately, there is not much you can do about sorting the Mark category other than what you have suggested. However, you could create an additional but invisible attribute that contains a '001' , '002', '003' kind of syntax. You could then sort on this and then hide the column when you create your table.
Would this work for you?
John Vellek
