imadHabash
en respuesta a: Anonymous
@Anonymous wrote >> I really did not get how it can take hatch and makes a polyline if these lines aren't meeting <<  for hatching this usual CAD behavior and there is a system variable called HPGAPTOL and from HELP (The default value, 0, specifies that the objects enclose the area, with no gaps. Enter a value, in drawing units, from 0 to 5000 to set the maximum size of gaps that can be ignored when the objects serve as a hatch boundary ).
also when you want to zoom in and out REGEN will help you to go in or either out.
Note:
what about your hardware acceleration ...would you try to Disable it ?
Imad Habash
