Alfred.NESWADBA
en respuesta a: Anonymous
what is "ANZACAD"? It seems to be an application on top of AutoCAD, so try to disable that app and see if loading of files can be reduced.
Additionally to the advices by @imadHabash I would ask you to copy your drawing and xref files to your local disk, then disconnect from network and try to load the file from the local drive, is that faster?
At least one additional question: are your files stored in the current format (DWG 2013)? Having set the default format to older dwg formats can result in such performance issues.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
