- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have an issue in drawing properties list used in title block...When i try to update my custom properties in drawing properties some or the other i am struck in between, (i.e.) some inputs are not highlighted after regenerating the same.....screen shot regarding the same is attached with. Thanks in advance.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
would you delete all the drawing elements and just keep the title block and share it here as CAD file?
note: don't forget to take a copy file from the original one ![]()
Waiting....
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for your response
Attached is the e transmittal file corresponding the same
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Your titleblock was a ways away from 0,0 so I moved it. I also used ExporttoAutoCAD since it apparently did not start life in AutoCAD.
I then redefined all of the Drawing Proeprties (I like to leave out the spaces in thenames).
I then brought it into a new drawing and it seems to be working fine now.
John Vellek
