- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi. There seems to be some issue with my cad. the lines when zoomed out seem to be meeting perfectly. but when I zoom in, I see they aren't meeting (the red lines in the attachment). Ortho is on. Snapmode set to 0. tried other values too but doesnot work. Snapangle is set to 0. Osnap is on and nearest is deselected. And it also makes a polyline with such non intersecting lines. If I try to hatch, it also takes in the hatch without any notifications of Closed boundary cannot be determined". Please help..
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi and welcome to AutoDesk Community,
such a problem causes by the user itself, i face it many times and the only reason that i found is the way of using object snap mode.i suggest to use (int) osnap for a while and see if the problem still exist.believe me you will find that the problem gone.why? because we use the right osnap on the right position.
try it and till us what you notice..
Good Luck..
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I really did not get how it can take hatch and makes a polyline if these lines aren't meeting. and also that if in an active command I try to zoom in, it does not allow me to. similarly it does not allow me to zoom out with my scroll wheel if any command is active and I've zoomed in to the extent it shows in the image.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote >> I really did not get how it can take hatch and makes a polyline if these lines aren't meeting << for hatching this usual CAD behavior and there is a system variable called HPGAPTOL and from HELP (The default value, 0, specifies that the objects enclose the area, with no gaps. Enter a value, in drawing units, from 0 to 5000 to set the maximum size of gaps that can be ignored when the objects serve as a hatch boundary ).
also when you want to zoom in and out REGEN will help you to go in or either out.
Note:
what about your hardware acceleration ...would you try to Disable it ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've turned off hardware acceleration and also checked with the value for HPGAPTOL. It is 0 but still I get the same issue. Attaching image for reference.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you share us the problem ( put a mark ) as CAD file please?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've also noticed that when I try to zoom in too much before it starts showing such non intersecting lines, sometimes my display tends to distort a bit. could this entire problem be a display bug or something?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is your AutoCAD updated to the latest Service Packs and Hotfixes?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
to know if the SP is loaded go to small arrow upper right of CAD screen beside the question mark (see images)
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
after opening your CAD file i notice another errors (green circles) this make me getting back to my (Post #2).what you are suffering from is caused by human errors.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The service pack shows M.107.0.0 AutoCAD 2016 SP1. I am not sure if its the latest one
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
and also when I gave the polyline command, I also noticed that the errors of non-meeting ends gets solved by itself as if the corners have been filleted.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
there are several ways to avoid or fix these issues.
As imadhabash already said; using object snap (OSNAP - F3) while drafting and carefully selecting which kind of snaps you want to have (END-MID-CEN-...) will greatly improve the quality of your work.
If you're drawing a line or polyline and don't have your object snap active you can shift+right click to select a snap for the next vertex of your line. Once you've placed that vertex, you will have no snaps active after that.
If you notice several lines not closing or joining, you can quickly join (J) + trim (TR) them by using the fillet (F) command with radius 0
For making a hatch you will allways need a closed polyline. Even if all the vertexes are connected that does not mean a polyline is closed. To close a polyline check the properties (PR)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I guess I will upload a video in which I am constructing lines with proper snaps but it still gives me such lines.
