- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello, I am a frequent poster on the Civil 3d group and have been using Autocad for many, many years. My problem is I have an xref that reports as INVISIBLE. I can overlay the xref normally and print. But close the drawing, re-open it is now invisible. The only way I can view the XREF's properties is selecting via SSX (Love SSX). Object reports as below. I initially thought somehow the object was hidden through the isolate object process. As you can see at the bottom, that is not what is happening.
So, I'm stumped and am asking for ideas on resolving this issue.
Command: SSX
Select object <None>:
Enter filter option [Block name/Color/Entity/Flag/LAyer/LType/Pick/Style/Thickness/Vector]: b
>>Enter block name to add <RETURN to remove>: _service*
Current filter: ((2 . "_service*"))
1 found.
Command:
Command: LIST
Select objects: p 1 found
Select objects:
BLOCK REFERENCE Layer: "xref"
Space: Model space
Invisible
Handle = 197b
Block Name: "_service_area_st_plane2"
External reference
at point, X= 0.0000 Y= 0.0000 Z= 0.0000
X scale factor: 1.0000
Y scale factor: 1.0000
rotation angle: 0
Z scale factor: 1.0000
InsUnits: Feet
Unit conversion: 1.0000
Scale uniformly: No
Allow exploding: Yes
Command:
Command:
Command: _AecUnIsolateObjects
Command: _.UNISOLATEOBJECTS
No objects to unisolate.
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
¡Resuelto! Ir a solución.
