- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Template files only affect new drawings, not existing ones. If your company has made the decision to switch from standard styles to SA-Standard styles, and if your legacy office content is expected to conform to the new style, you will need to open each drawing and update the styles. Any blocks stored in block library files will need to be individually block edited and changes made. Any attributes must be modified by using attsync or battman..
Automation is possible via LISP and .NET to make these changes to libraries of drawings. File dates will change though and updated files may not be openable in older versions of AutoCAD.
HIre someone to make the changes who understands how to automate a transition to your new policies. Establish and plan the process. Otherwise these haphazard results will be typical.
