08-13-2016
11:41 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-13-2016
11:41 PM
and the difference is what I told you already at the first response, In drawing "xxx(1).dwg" you have a 3D-Solid, in the ohter drawing ("xxx(2).dwg") your object is a surface, that makes the difference.
Make sure your polyline is closed before you start the _REVOLVE command (and within the command verify with parameter _MODE that objects of type "SOlid"s are created).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
