- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Leader arrow won't move when repositioning note
Leader created using QLEADER. Moving the leader will move everything but the arrowhead. It seems to be locked in place. Even moving the entire drawing has no effect. Solutions?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try to do :
- Disable Hardware acceleration.
- Download latest Service pack & Hotfixes.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No sir. The command isn't completed yet. If it were exploded the arrow would move. The arrow seems to be locked into that spot and cannot move. I've moved all of the associated geometry and still nothing.
I think I may reload the software. This is something I've never seen before.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi, I had the same problem with this leader. Everything in unlocked & thawed but still its seem to be locked in place. I hope autodesk could fix this.Thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I believe there is something corrupt in your drawing that is causing this behavior. I can move the leader line and the Dot remains in its original position. Then I run Audit and the Dot moves to the new location.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi, @john.vellek,
I tried running an audit but the problem remains the same. I agree with you. there might be a corrupt in the file. Thank you very much anyway.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
Help is appreciated, but I'm in the process of reloading the software. My schedule doesn't allow me much time to troubleshoot problems that can be fixed with a fresh install and setting import. If it continues after the install I'll do as asked.
Wait, you have just enough time to ask for help but you don't have time to help those that want to help you? Good luck!
Doing a fresh install is a waste of time unless you are completely at a loss. You have not learned anything by doing that and won't know how to fix or prevent it from happening again. It is probably a simple fix that will save you time in the future because you won't have to lose production time when you are doing the fresh install.
"An ounce of prevention is worth a pound of cure."
Find the time for troubleshooting.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Five years later, posting a fix because I just ran into this same problem.
My fix: type SHADMODE at the command line, then 2. It was set to wireframe accidentally.
The error happens on leaders that use a custom block for the arrowhead. Leaders with built-in arrowheads work fine. This error and fix worked in AutoCAD 2021.
Design Master Electrical RT
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I had the same problem and that solution with changing the shademode solved the issue. Thank you very much for your help.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
7-1/2 years later, thank you David Robison. I've had this issue for years, SHADEMODE fixed it. With so many miniscule drawing functions it's extremely frustrating not knowing these arbitrary settings.
