- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi everybody. i´m doing a presentation of a 3D model in paper space and i want to use leaders to point equipments but i´m having 2 problems.
1-Leader desapears after i write the text when i snap a point of the model, but if i start de leader with out snaping any point it stays.
2- The second problema its that the leader that i make wothout snaping any point it´s not an associative leader and it doesnt let me reassociate to any point.
any ideas why? im using autocad 2016
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try setting DIMASSOC to a value of 1
FYI...
DIMASSOC = 0 (makes exploded dims and leaders)
DIMASSOC = 1 (makes non-associative dims and leaders, which means they stay intact but are not associated to the object being dimensioned)
DIMASSOC = 2 (makes associative dims and leaders, which means they are associated to the objects being dimensioned in that if the object changes, the dims and leaders also change)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I have tried to recreate it. Neither does my leader disappear nor is it disconnected from the model, when I move the view. Except, I did something else then you did.
It may be beneficial if you could send a screencast, showing your steps and the results.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This is when you open this drawing which has already the leader in it? Or did you create them and at the next moment you lose the associative connection?
Can you please upload the drawing? Or maybe a smaller one? BTW does it happen to all your drawings or this particular one?
Regards
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
it happens only in this particular file, when i start drawing the leader and lose it, as a matter of fact when i draw a leader from some point of the model and then lose it, the leader desapear, it doesnt stay in the drawing, so i have to draw the leader from any point and then move it to where i want to point to.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Could you export the drawing with wblock to have it purged and then create the views again. See how it reacts then...
Regards
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hi, i did a copy paste of the drawing in a new file and it worked out well.
thanks for the help ¡¡
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Well, then glad to hear it work out ![]()
Please mark your post as accepted solution so that other reader can benefit from your experience.
Thank you for your contribution
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You are welcome ![]()
As for your question on which software to use...
Well, I do not know Plant 3D - I am an Inventor girl
so I am not impartial enough to give advice. From what I see, your drawings are realizable in Inventor. And this is how far I can go.
But whatever you decide the community is here to support you ![]()
Good luck
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
