- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi. I am having a problem with Autocad 2016 and the xref notification.
When an xref that i have in my drawing is amended and saved by another user i get a balloon notification to say that it needs reloading. However, when i open a drawing where there were xrefs previously but have been moved or renamed i only know about it if i read the command line while the drawing loads. I don't get a box coming up anymore that says its cant locate an xref and do i want to update the location or ignore.
I have looked through the forums and made sure that xrefnotify is set to 2.
Is there another variable or have i (or someone else) done something to the set of drawings to prevent the pop up?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Do you mean that you do not get this dialog when opening a drawing with missing xrefs?
If so, then go to Options > System Tab > General Options > Hidden Messages Settings
Then check the appropriate box, and press OK.
The next time you open a drawing with a missing reference file, you should get the first dialog above, again.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
go check this one out: http://forums.autodesk.com/t5/autocad-2010-2011-2012/xref-reload-notification-bubble-not-appearing/t...
CADnoob
