hamish.maclean
874 Vistas, 8 Respuestas
3d objects losing grips
When moving objects in my 3d model everything seems to work fine and I save and close but occasionally when I reopen the drawing I find the objects I moved or worked on in my last session have been separated from their grips which are in the new position.
I have tried the work arounds (cut and paste etc..) but the only one which works is double clicking the offending objects grip and it jumps back to position. This however is very time consuming as there are usually a lot of objects moved in a session.
Am I doing something wrong when moving the objects or is this still a known issue with autocad
Etiquetas (1)
