- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:I'm not sure if it was just the standard drawing annotation scale that was changing, or if they had something different set up.
It was set up so we could pick 1/2"=1'0" and it loaded up a specific dimension style, and the leaders would automatically come in at the correct size. Then we could switch it to 1-1/2"=1'0" and it would change it to that specific dimension style and leader size. Everything would then come out on paper space the same size.
If you add the scales to the respective elements it will behave this way though it wont change styles for you...
here is a deception for an AU talk from 2008 http://www.dscohn.com/AU/handouts/GD315-1P%20Annotation%20Scaling-DOC.pdf
It would be interesting to have a feature that changed all the styles based on the scale.
CADnoob
