TheCADnoob
en respuesta a: jkulpa
Its odd that you reach out to the support community for this sort of information. I also find it odd that you are tired of the updates but seem to be boasting about your newly updated hardware. The updates Autodesk makes are some times intended to make use of bells and whistles in your new hardware. So im not sure you are giving a fair shake when you seem excited about updates in one arena and not in the other.
You shouldn't be crashing, but are you sure the reason you are crashing is due to AutoCAD or perhaps an improper optimization?
I totally feel your frustration about crashing. My program crashes about three times a day. This sounds bad, but this is not the fault of Autodesk. There are third party apps that are causing some of these crashes and there other issues i face are network related. The reason i know this is because i spent time chasing the problems down.
What step have to you taken to ensure you are not having 'external' issues? It might help to talk to your re-seller as mentioned.
CADnoob
