- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I've built a solid model with handful of parts that are assembled from XREFs. Each XREF component being copied moved and rotated numerous times. I would like to know if there is a way, once I have finished editing all of the XREFs to import them as actual solids that maintain their final positions.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
if i understand your question... the answer is basepoint (0,0,0).link every part with this basepoint to manage dealing these parts.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Look into binding them. You can do that from the XREF manager by right clicking on each item in the list and selecting BIND. There are two options for binding, insert and bind. The bind option will add the file name as a prefix to layers, text styles, dimstyles, etc. Not always desirable unless you think there is a chance that both files have different definitions for the same name. Using the insert option, anything with the same name will take on the properties from the referencing file.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
If I am understanding your question correctly, I suggest that @RobDraw's suggestion of an Insert Bind might be the answer. Here is an Article that might get you started. I suggest you try it on a copy of your host file to make sure that everything works the way you want.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
