07-25-2016
06:51 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-25-2016
06:51 AM
@CADmonkey_UK_Building_Services wrote:Unless you need Hotfix #4, I'd say congratulations! You've solved your own problem! You should notify Autodesk with a Support case.
The Nvidia drivers need to be those listed on the Autodesk Hardware lists, and not the latest versions.
Or maybe the Nvdia card is too weak for your purpose?
Of course, we're using Hardware list drivers.
And, the changelog it suposed to fix two problems we have:
- Crashes when opening using Windows 10
- Copying and pasting a block
The NVIDIA card it's okay. The files aren't too hardware demanding.
Now seeing we're not the only ones with this problem.
