TheCADnoob
en respuesta a: Anonymous
Id talk to your reseller. with the advent of the industry collections model you will likely have access to things that already have these sorts of systems built into them. Plant 3D pull parts from a database and you just drop them in. super easy! you can control the parts using selected standards and its a real easy interface to work with. They also have a steel section of Plant 3D. Some of the structural guys i know says it didnt do enough so they are using advanced steel, but i believe Autodesk has made and is making improvements since the last time i spoke to those guys.
http://www.autodesk.com/products/autocad-plant-3d/overview
http://www.autodesk.com/products/advance-steel/overview
Im not saying dont learn lisp, but i wouldn't spend time reinventing the wheel especially if you will already be paying for the license of these programs under the SAS collections model.
CADnoob
