2894 Vistas, 6 Respuestas
License manager is not functioning or is improperly installed AutoCAD 2017
Hello, I tried both solutions here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
and neither solution worked. Tried uninstalling and reinstalling as well, any other suggestions?
jasmin.gonzalez
en respuesta a: Anonymous
Hi @Anonymous Welcome to Autodesk Community!
Sorry to hear the issues you are having with the license manager.
I created case number 12004390 and escalated it to our Installation & Licensing Team so they can assist you with the proper installation. They will be contacting you directly via the case.
Jasmin Gonzalez
Same problem. Please help.
BHOBEN_MVCampus_CADD
I run a lab of 45 computers and all are working fine with a network license except for one that is giving this error. I am coming close to wiping the operating system so I was trying to see if any new progress in fixing it has been made?
en respuesta a: BHOBEN_MVCampus_CADD
I was using a stand-alone license on a single computer. We ended up having to complete an offline activation for this machine as all previous troubleshooting failed. The Autodesk tech support team assisted.
en respuesta a: jasmin.gonzalez
I have the same issue and have tried the 2 solutions but still not working.
Has another solution been found or will I need to raise a ticket
I am having the same issue again installing this same license for the same user on a newly imaged hard drive. The resolution for this the first time it happened was for me to generate a request code and an Autodesk support person emailed me a 56 digit activation code. I need assistance again to receive a new activation code.
