07-19-2016
05:25 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-19-2016
05:25 PM
Unless you need Hotfix #4, I'd say congratulations! You've solved your own problem! You should notify Autodesk with a Support case.
The Nvidia drivers need to be those listed on the Autodesk Hardware lists, and not the latest versions.
Or maybe the Nvdia card is too weak for your purpose?
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
