en respuesta a:
10:56 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-19-2016
10:56 AM
@Anonymous wrote:Hi
i have broken one object which was single using explode command, But after editing some part of it i am not able to export it to STL format. So i need to re-combine all the poly lines to one object and then i can export to STL Format.
I have attached .dwg file and also screenshot. I am unable to use join command it gives me error. 36 object discarded from operations 0 objects joined.
Seems like it'll be easier to just recreate it than to mess with all of the regions and surfaces you created by exploding the original object.
