6671 Vistas, 6 Respuestas
Combining object into single solid object
Hi
i have broken one object which was single using explode command, But after editing some part of it i am not able to export it to STL format. So i need to re-combine all the poly lines to one object and then i can export to STL Format.
I have attached .dwg file and also screenshot. I am unable to use join command it gives me error. 36 object discarded from operations 0 objects joined.
Etiquetas (3)
