- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi
i have broken one object which was single using explode command, But after editing some part of it i am not able to export it to STL format. So i need to re-combine all the poly lines to one object and then i can export to STL Format.
I have attached .dwg file and also screenshot. I am unable to use join command it gives me error. 36 object discarded from operations 0 objects joined.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I want to do the same. I have exploded the object but i am unable to make it 1 single piece solid again, so i am unable to export it to .STL format.
Please help me with joining this multiple exploded objects. I use group command but it doesn't make single solid object. its not working either.
Please hep.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:Hi
Seems like it'll be easier to just recreate it than to mess with all of the regions and surfaces you created by exploding the original object.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Explode 3d in autocad is not good.
Use PRESSPULL or LOFT command on the red part, then move your parts together, use UNION command then STLOUT.
