TravisNave
en respuesta a: Anonymous
-15 is usually due to a couple of different problems (as explained above.)  First make sure your NLM is running and licenses are available by performing a status enquiry in LMTOOLS.
1.  IPv6.  You must be able to PING the server from the client and it must be able to get the correct DNS to IPv4 translation. If it comes back with an IPv6 address, then make a hosts file entry to correct it.  If it cannot be PING'd then you need to allow ICMP to your firewall exceptions.
2.  Firewall blocking 27000 and 2080.  You need to make exceptions for lmgrd.exe and adskflex.exe and/or TCP 27000 and 2080.  You can test this from the client using Internet Explorer (only IE works.)
http://servername:27000
http://servername:2080
Replace servername with your server hostname.  The result should be a jargon page.  If you get a 'Page cannot be displayed' error, then your ports are blocked.
3.  Rare, but it could be a problem with your NLM version.  I have found that LMTOOLS version 11.7 is the most compatible with all Autodesk products to date (2004-2017) and if the problem persists, you might try this version.
Good Luck!
Autodesk Forums:
