07-15-2016
03:49 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-15-2016
03:49 PM
Hi @efransen, I don't see your file attached
Can you Zip it up first ant then retry?
Also, if reloading the Acad menu still doesn't have tabs then you I suggest a Reset Settings to Default might be the easiest way to get things back to normal although you will need to add back any customizations.
If that brings everything back to "factory settings" we can explore why your custom menu is not working properly.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
