284 Vistas, 2 Respuestas
Gathering Attributes from Blocks that are Connected or Intersect a Path
I work a lot with P&ID's and I'm looking for a way to collect the attributes of blocks or objects that are positioned along a line/path/poly to map source-destination relationships. I realize AutoDesk P&ID does this but convincing my employer to fund the purchase is another matter. Might anyone have any advice on achieving such?
john.vellek
en respuesta a: Anonymous
Hi @Anonymous
Welcome to the Autodesk Community!
You might be able to do this.  When you create a Attribute Data Extraction you have the ability to also capture the x,y,z position of the attribute as well.
If you would like to attach a sample drawing I can help you create an extraction.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
