- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am running AutoCAD 2013, straight out of the box, network license.
AutoCAD was working this morning.
I tried to open a vendor file, "drawing file is not valid"
Here's the part that's hard to explain, so please bear with me.
Autocad opens. Ribbon is up, model space is there, properties window on the left, all looks normal.
I can select ribbon buttons. I can select property items. I can even select those little buttons on the bottom. I can open other drawings.I can switch to paper space using the bottom right button. (Not the tab)
BUT
nothing in the drawing area is accessible. If I click line or circle (or anything else) The command bar shows that the command has been engaged, but when I am in the drawing area the cursor is still the windows arrow, not the ACAD crosshair.
I can click the command bar, but nothing shows up when I type. It's almost as if the drawing area is a screen shot, not the program.
Rebooting helped once, but no longer.
Anyone got anything?
¡Resuelto! Ir a solución.
