416 Vistas, 3 Respuestas
AutoCAD 2017 Installation Failure
I am attempting to set up a network deployment for the installation of ADSS, BDSP and IDSP.  I have found that our Antivirus software has been blocking the installation and has to be disabled on each machine prior to the start of the installation.  Is there anything that I can "whitelist" on our AV software package that will allow the Autodesk installation to run uninterrupted without me disabling the AV?
john.vellek
en respuesta a: Anonymous
HI bjames,
I can understand your pain point with your deployment. So far all the information I have been researching just indicates to turn off the security software prior to deploying. I am reaching out internally to see if some of our specialists can provide a list of exclusions that would allow your deployment to run without disabling the AV.  This might take a day or two to gather information but I will update this post as I find out more.
Thank you for your patience
John Vellek
Alfred.NESWADBA
Which AV software do you use?
(and have you asked the vendor of that software too?)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
We are using McAfee. Our IT Security department has McAfee specialist so I am not sure whether they asked McAfee if they had a solution.
Brian James
Document Configuration Manager
Office of Infrastructure Services
Department of Transit Infrastructure & Engineering Services
Construction & Design
Washington Metropolitan Area
Transit Authority
600 Fifth Street, NW
Washington, DC 2001
202/962-2836
Fax: 202/962-2039
Cell: 202/384-6908
