- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Panning with Logitech M560 Mouse
Whenever I use the middle button to pan, it switches between open tabs. For example, If I have a file open and the Start Tab is beside it, when I click and hold the middle button to pan in my file, it switches to the Start Tab. I am using a Logitech M560 Mouse. Before you ask, Yes, I did download the appropriate mouse software and programmed the middle button to be used in this fashion. I was using the function fine for several weeks up until this morning when I opened AutoCAD and this issue started. I am using AutoCAD 2017 Student.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Give this a gander and see if it helps
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I might also double check the button assignments in the driver utility. Sometimes i have better luck with generic windows drivers with some peripherals so you can also try uninstalling the driver as well.
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Unfortunately this was only a temporary fix. It is no longer working. I have no idea how that makes any sense - how it could work for a while then stop working again without me changing any settings is baffling.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No, they did not change. After I changed them as it told me to, the CUI value remained the same after I closed the CUI window. I even re-opened it to check and made sure that I had hit "Apply" before closing.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
have you checked logitech forums?
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Im about to murder my M570 cause of a bad button so its not beyond the scope of possibilities that its the mouse. it does sound like an odd problem though. Does it functional as it should in other programs?
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The Logitech SetPoint software has created problems for me in the past. When not installed, no issues.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This problem occurs when you use some models of Logitech® mouse [like my M560], that changes the regular escrow to smoot mode when you press the wheel.
The way I find to solve it in Revit® and CAD® was use the command “PAN” at the keyboard, and them use the left bouton to pan. Otherwise, I use also my old M280 mouse in such programs, due it don´t have the dual mode wheel.
There is the only way to solve your problem. That´s all my friend. Thanks TOM.
@Anonymous wrote:Whenever I use the middle button to pan, it switches between open tabs. For example, If I have a file open and the Start Tab is beside it, when I click and hold the middle button to pan in my file, it switches to the Start Tab. I am using a Logitech M560 Mouse. Before you ask, Yes, I did download the appropriate mouse software and programmed the middle button to be used in this fashion. I was using the function fine for several weeks up until this morning when I opened AutoCAD and this issue started. I am using AutoCAD 2017 Student.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Not true. Other solutions and possible causes were given.
Rob
