883 Vistas, 7 Respuestas
Intersect on 3d corner in AutoCAD Model
I am trying to create a corner for molding on a rendering. I created a molding profile and joined the polylines. I then extruded the shape and copied it. I rotated the copy 90 degrees and aligned the two shapes. I have tried to intersect the two solids to create a 3D mitered corner. but the intersect command  does not intersect. The subtract and union command will not work on these shapes/solid either.
@Anonymous, john.vellek has edited your subject line for clarity:Interset command dose not work
