john.vellek
en respuesta a: Anonymous
Hi Seth,
I think then it is time to use the Windows Control panel > Programs. Remove all the AutoCAD 2017 stuff you find there.
Next clear your User TEMP folder, remove the installer folder and any other AutoCAD 2017 folders you find on your system.
Verify that you have the correct C++ and .Net installed (see the Best Practice I sent you earlier)
Next, check to make sure that you have all the windows updates installed. Reboot and don't let any applications run.
Turn off your Firewall and any anti-virus software.
Again, use the Virtual Agent or go to your account page and use the BROWSER download (ends up in two files I think).
When you start the install, rt-click the install file and RUN AS ADMINISTRATOR.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
