john.vellek
en respuesta a: Anonymous
Hi Linda,
When I place all the blocks into a single file (run BLOCKICON) and save them they show up properly in Design Center.  As another step, some users have found that making sure that background color is set to white helps the icons show up properly in Design Center.
Will this work for you? I usually keep all my standard blocks in select files to use as a library so I can group them and manage them easier.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
