07-07-2016
04:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-07-2016
04:00 AM
One of the automatic approach is to set up a sheet set, define the revision number in the sheet set properties, then use a FIELD in the title block attribute to refer to that revision property value.
In that case, you only need update the revision property in the sheet set once and all drawings with the same title block setup will get updated automatically.
