szhang
844 Vistas, 9 Respuestas
Dimension text moved after file saved.
Hi Sir / Mam,
I am having facing this issue with AutoCAD 2016. (please see attachments)  The problem is whenever editing a dimension text which is too tight to fit between the dimension lines. After the file is saved and reopen, the text repositioned to its original place. This only happen to AutoCAD 2016, when I open the same file with AutoCAD 2014, everything is fine.  I have double checked and compared to make sure all setting in Dimension Style Manager between AutoCAD 2016 & 2014 are the same. As for Dimension Variables both DIMATFIT <3> & DIMTMOVE <0> are identical for AutoCAD 2016 & 2014. I am hoping you can help me out…..my last resource would be to uninstall AutoCAD 2016 but that means I will have to setup everything all over again.
Song Zhang
