- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
How can I get the command for Dimensional constraints.? Earlier it was very easy to select the command in Autocad-2012 tool panel. But in the 2016 version, neither it's showing in tool panel nor with short command.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
do a rightclick in the grey area of the workspace and activate your dimension panel.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
activated yet. I have attached some screenshots also for your reference.
Please check it accordingly and help me to get the 'Dimensional
constraints' command.
Regards
Rajith
+919743508486
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Please recognize that I'm a user like you too ![]()
It seems then that your menu was modified, you can try to change to another workspace or to reset your settings to default so your menu also is changed to the original one as after installation.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have tried that one also. But there is no 'dimensional panel' is activated yet. Of course the dimensional pane is showing on the tabs. But am facing the problem with getting the command for 'Dimensional constraints'. It was easier to get in the 2012 version as its directly showing on the tabs, but not here.
I have attached some screenshots also for your reference. Please check it accordingly and help me to get the 'Dimensional constraints' command.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have the same issue. The panel and options where you could set up those constraint dimensions is just not an option for us! How can we enable them? I have fresh autocad with no modifications
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
...also not migrated settings from a previous AutoCAD release, ... or using AutoCAD LT?
As you stated "with no modifications" you can try to reset settings to default as described >>>here<<< (and make sure to NOT migrate settings if you are asked to do that).
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Type in the command CUILOAD and unload the ACAD customization file and try reloading the same. Hope this works in AutoCAD LT. I have attached the screenshot for more clarity.Unloading the CUI
Reloading the CUI
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
