soworu
9660 Vistas, 8 Respuestas
OVERLAYING 2 DRAWING
Im a CAD newb and have got 2 drawings that are in model space that i need to overlay to compare. Both of them are from an architect (i work for a main contractor) and we have moved a building to suit construction sequencing.
Any help would be much aprieciated.
Patchy
en respuesta a: soworu
Use XREF command
imadHabash
Hi and Welcome to AutoDesk Forum,
Xref is the most power way to use and because you're newb as you said i advice you to convert one of your plans or both to BLOCK and then you can compare them as you like.
Good Luck..
Imad Habash
XREF is probably the easiest and quickest way of doing it, or you can convert it to a block as stated above, but make sure you paste to original coordinates if you're working to the same coordinates as the architect. It'll save you the trouble of aligning it.
RobDraw
Manual comparison can be quite tedious and could result in missing stuff, especially in a large or busy drawing. There are programs to help you with this.
Here's one:
https://apps.autodesk.com/en/Detail/Index?id=136068404068200943&appLang=en&os=Win32_64
Rob
Martin_Langolf
Hi soworu,
Can you advise if any of the provided suggestions helped to answer your question?
If so, please mark a reply that helped as an accepted solution or let us know if you have any further questions.
Cheers,
Martin
Martin Langolf
soworu
Martin,
Thank you for your support and I really appreciate your effort. The answer to Re: Overlaying 2 Drawing was successfully.
Thank you very much.
Sunday
Sunday Oworu
Civil CAD Technician
[RA Logo]
4 Centrus,
Mead Lane,
Hertford,
Hertfordshire,
SG13 7GX
Mob: +44 (0)7741311826
Tel: +44 (0)1992 663080
Tel: +44 (0)1992 669386
Fax: +44 (0)1992 663081
soworu@reachactive.com
www.reachactive.com
Martin_Langolf
Hi Sunday,
Thank you for your confirmation.
I have marked the provided suggestion above as an accepted solution for you, assuming this was the suggestion that answered your query.
Cheers,
Martin
Martin Langolf
en respuesta a: imadHabash
Sir,
I want to wrap a external vector file or AutoCAD file on the surface of the 3d cylinder.
I want to wrapping a vector grill like this image.
