Kent1Cooper
en respuesta a: cturlington
@cturlington wrote:
I have been able to create a right window selection in the past.  But lately, I have been unable to select anything using a "right" window.  Is there a setting that turns this ability on/off ?
Do I assume correctly that you're talking about picking a window in the rightward direction [second corner to the right of first corner], for a fully-contained-in-the-window selection rather than a crossing-the-window selection?  If so, are you talking about selecting without a command active [Darin.Green's PICKFIRST suggestion], or at a Select-objects prompt within an active command?  Does leftward crossing-window selection work when a rightward window doesn't?  I'm not aware of any setting that would affect one but not the other.  Does individual item picking work?
Kent Cooper, AIA
