473 Vistas, 5 Respuestas
64 bit os
trying to load up AutoCAD 2017( free student version) my system runs Windows 10 with 64 bit OS. AutoCAD installation starts up but there is no create deployment option I get just install tools and utilities. it starts to install then it stops and I get a "failed" message didn't finish downloading and installing
How do I fix this problem? any suggestions.
JDMather
en respuesta a: Anonymous
@Anonymous wrote:
trying to load up AutoCAD 2017( free student version) ...
 didn't finish downloading and installing....
Are you trying to install Student license or Educational Institutional license?
Deployment option would be for institutional network license. Student license is single seat, not network.
Download the two files from here http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
TravisNave
JD is right.  You shouldn't be deploying anything.  Just install like normal.  If it fails installation, then post your installation log and we'll take a look at it.
In the mean-time, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Autodesk Forums:
JDMather
If you are looking for a free educational institution network license - check this link.
en respuesta a: TravisNave
thank you Travis the suggestion you made in ref to using Virtual Assistance worked.
TravisNave
Excellent!  Glad you are up and running!
Autodesk Forums:
