06-28-2016
10:54 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-28-2016
10:54 AM
I might consider making a block with joined polyline squares that encompass the entire circle. Then explode the block and erase the objects you don't want with a fence selection around the circle. Be sure to turn off running osnaps. Any squares that hang over will be selected in their entirety and removed. You may have to go select a few that you miss with the fence, but they can be removed with a single selection instead of having to remove 4 lines separately. Still may be a bit time consuming though. The best idea I can come up with. Hope it helps.
