06-27-2016
11:38 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-27-2016
11:38 AM
So, for some reason his AutoCAD was opening up 2 instances. He closed AutoCAD and went to reset as you wanted us to try. It said there was still another instance running. Using Task manager he forced the 2nd instance to shut down. When he loaded AutoCAD after that, the overflow issue stopped happening. So, your solution caused us to find the problem. If the problem comes back he will try the reset. Thank you for your help!
